Chevrolet Equinox
Platform: Theta
Leaky Transmission cooler line R & R
Old May 5th, 2015, 12:05 AM
ruley73's Avatar
Default Leaky Transmission cooler line R & R
I just wanted to let you all know that I just had to replace the transmission fluid cooler line assembly (OEM part number 15781494) on our 2007 Equinox FWD at 123,700 miles. It was starting to leak at one of the crimps. If anyone else ever needs to do this you will need to drain and replenish about 4.25 quarts of fluid (I measured what I drained). GM still wants almost $19/qt for the genuine stuff, so I bought some Toyota T-IV fluid from my local Toyota dealership (again) for a more reasonable $5.74/qt. I put about 4.5 quarts back in to account for what had leaked out and that brought the level up to the top line of the cold range on the dipstick (pictured below). I checked the fluid with the engine running after starting up and cycling the shifter through all the gears (did not drive beforehand). This pic was taken when I did the complete fluid exchange a few years ago. I colored the raised edges with a permanent marker so you can see the marks.
I forgot just how hard it is to get to the dipstick. You're much better off removing it from under the car than under the hood. The color of the fluid was still fairly red but had a little darkness to it.
Lonestar
December 18th, 2018 9:00 PM
zagfan1989
September 27th, 2011 12:42 PM
jtprice
January 5th, 2011 9:37 PM
24fb freedom
July 8th, 2009 11:43 PM
pecos
Astro
March 1st, 2009 5:06 AM
Quick Reply: Leaky Transmission cooler line R & R
