loud noise in front end
![Exclamation](https://chevroletforum.com/forum/images/icons/icon4.gif)
have a loud noise in the front end and get louder with the increase of speed just recently changed the carrier bearing and the u joint and still making the same noise...n e suggestions?
The most likely causes are sway bar links. They have ball sockets that wear out and cause a noise over small bumps or a rough parking lot. They are the thin links that hook to the strut and to the bar going across the car to the other side. If the noise coming from the front suspension while traveling over bumps in the road, it's because of bushings in the control arms. They will need to be replaced. If your front suspension squeaks while bouncing, it can indicate that the shocks are worn and need to be replaced.
Could you describe the noise? Is it moaning/groaning, ticking, clunking, banking, squeaking, thumping, whistling, or squealing? Does the noise vary with engine RPM or vehicle speed?
the noise that im hearing is a growling like a wheel bearing..when u turn to the left and right you hear it, even going straight. it gets louder with the speed of the car...
Official GM Rep
millerlls220,
Let us know if you are interested in having your GM dealership look into this concern. You can always reach out via private message.
Erica Tiffany
Chevrolet Customer Care
Erica Tiffany
Mr.Cale
January 15th, 2012 5:39 PM
ClintM
Sonic (Aveo)
June 20th, 2011 11:51 AM
