Chevrolet Equinox
Platform: Theta
need advice
Old Nov 6, 2013 | 1:44 PM
Mlthumper's Avatar
New User
Awaiting E-mail Confirmation
Unhappy need advice
I have a 2007 equinox. Awhile back while driving using the cruise control; all of a sudden the car would start shaking bad. Took it out of cruise control and everything ran fine. This was the 1 sign for trouble to come. Took it into my mechanics shop. He ended up replacing the brake switch and had to have brake roter replaced. The car ran fine for a couple of miles and then acted like the car had the brakes on. emer. brake was off also. Took it into the dealer and they said the brake switch needed reset. They did that. Ask another mechanic and said to remove the vacuum hose from brake booster and if any liquid in it, it needed replaced. We bought a new master cylinder and brake booster and had them installed. But it still acts like the brakes are on. Finally got a code no. it is C0131. would anyone know what this code means. no one seems to know what the problem is.
Old Nov 6, 2013 | 3:22 PM
Welcome to the forum...
I Google'd the error code and found this....
DTC C0131-C0139
DTC Descriptors
DTC C0131
Antilock Brake System (ABS) Pressure Circuit
DTC C0136
Base Brake System Pressure Circuit/Sensor
DTC C0138
Base Brake System Pressure Circuit/Sensor Low
DTC C0139
Base Brake System Pressure Circuit/Sensor High
see the attached pdf I also found with it...
File Type: pdf
Old Nov 6, 2013 | 10:44 PM
Tech's Avatar
C0131 is generally a problem with the BPMV. Brake pressure modulator valve. It is the unit that houses the valves and solenoids to control ABS events. I believe that the BPMV comes with a new EBCM but fully certain on 07 equinox's. Sorry, but the best bet is to have dealer diagnose it again to be for certain. The last c0131 set in an 08 equinox I had ended up needing a BPMV. But doesn't mean that each one is similar. Also more things to check make sure all air is purged out of brake system. Make sure master cylinder is good. And also make sure you didn't by any chance put the wrong fluid in it or previous people that worked on it. If you contaminate brake system with a fluid like power steering fluid it will cause seals to swell in brake system and that will cause the brakes to feel like they are dragging at all time. I know I gave you a lot of checks but there are so many different scenarios and I'm trying to touch base on all of them
system
Jun 8, 2006 9:07 PM
nicom
May 8, 2006 12:32 AM
Chevy1500Project
Apr 3, 2006 4:46 PM
DennisT
Jan 16, 2006 2:11 PM
