Need help !!!
05 Equinox LS in great shape, except I have a problem with the AC !!![Mad](https://chevroletforum.com/forum/images/smilies/mad.gif)
Took it to 5-different ac shops and all said the compressor was bad. Took it to one more shop they changed out the ac relay in the fuse box under the hood and the ac worked for 4-days (blowing cold and working like normal).![Big Grin](https://chevroletforum.com/forum/images/smilies/biggrin.gif)
The correct amount of freon is in the system.
Today the compressor stop working again. I'm like what the heck !!![Mad](https://chevroletforum.com/forum/images/smilies/mad.gif)
I replaced the relay and nothing !! However I can hear and feel the relay making a clicking sound when the ac is turned on while I'm inserting it or removing it !!
Please help as it's getting hot here in TX.
Thanks in advance !!
Does it only blow warm or less cool air at idle? If so, the scroll valve is bad. You can replace just the valve, but it would require the refrigerant to be evacuated and refilled.
It could be a bad compressor clutch too.
Thanks for your reply. Yep, it used to blow warm or less cool air at idle. I had the scroll valve replaced in the summer of 2013 and all worked fine until late summer of 2014 and that's when the compressor stopped working.
I still would like to know if I can feel and hear the relay clicking, does that mean the relay is trying to do it's job or it it something to do with a wire in the fuse box etc ?
If it's the compressor clutch, how do I test it to make sure that's what the problem is ?
Like I said before most shops (small mom and pop shops) are saying it's the compressor. I have doubts about the compressor being bad as it did work and blow cold air for 4-days last week.
Thanks again for any info......
be_Martinezr
October 6th, 2014 10:19 AM
1stTahoe
April 19th, 2012 9:44 PM
upzaw2000
HHR
December 31st, 2006 9:36 PM
