No heat 06 equinox
This!!
there is a recall for 2006 models.
Gm has issued a special tool for this repair. It will install a sleeve over the broken blend door in vehicle. If all goes well, its a 1 hour fix instead of 6.5 hours to remove and replace the blend door...with the same part that will break in another 6 years. The sleeve repair will not break.
Check the top hose to your coolant reservoir. I pulled mine off and stuck a coat hanger into the reservoir. Turns out it was clogged and not allowing the coolant to recirculate back into it. Fixed my no heat at idle! Something so simple. SMDH!
that fixed mine hoses were clogged
