Chevrolet Equinox
Platform: Theta
Odd complication
Old Jan 15, 2025 | 6:24 AM
SaMMiJo's Avatar
Question Odd complication
I just bought a 2013 Equinox and for a while I thought the windshield washer fluid pump was not working, but it turns out it is. The problem is that when I activate the front washer fluid sprayer, it sprays the back window, and when I activate the back one, it sprays the front. As a result, if I ever need to clean one of them, I have to do both because, either way, one will spray and the other will wipe. Anyone know where the wires might be crossed?
Old Jan 15, 2025 | 7:35 AM
Welcome from Florida. The wires are probably crossed at the switch.
Old Jan 15, 2025 | 7:39 AM
Gumby22's Avatar
Most likely the hoses were switched at the pump during a repair.
You might be able to see/access the pump hoses from underneath, but most likely you’ll need to Remove the driver side fender liner (wheel removal will make it easier but not required).
Refer to the illustration below - the rear washer hose connects to the front of the pump and the windshield washer connects to the rear of the pump.
[img alt="1 = Rear washer feed
2 = Windshield washer feed
Tank & pump are behind the driver side fender liner."]https://cimg6.ibsrv.net/gimg/chevroletforum.com-vbulletin/1179x696/img_5794_d9fbf27b66af3bd8e11718c7e65a7a5b4a3254c5. jpeg[/img]
1 = Rear washer feed 2 = Windshield washer feed Tank & pump are behind the driver side fender liner.
If that doesn’t resolve the issue, it’s possible the wrong pump was installed and/or the wiring at the connector was switched. I can advise you on the next steps if needed.
Old Jan 17, 2025 | 2:48 PM
BlueOx's Avatar
Because the wiring is via a molded connector it's more likely the hoses were reversed when the pump was previously replaced.
Old Jan 25, 2025 | 10:12 AM
Stove's Avatar
Just got an 07. Driver nozzle was plugged. I cleaned it out gently but spray is way off. Just dribbles. I swapped pass for driver nozzle but I think angle of spray is different on each side? Looks like new nozzle time.
Old Jan 26, 2025 | 10:15 PM
Moonwink's Avatar
Try using compressed air to blow it out. Rinse it a couple of times and use the air on it a few times in between rinses.
Old Jun 5, 2025 | 9:35 AM
rhcdmd's Avatar
.Agree. Most likely the front and rear hoses are switched.
Syncman
Dec 9, 2024 2:16 PM
Julz44
Feb 20, 2016 9:33 PM
papawali
Jan 3, 2013 6:16 AM
rdc1534
Uplander
Nov 11, 2009 10:44 PM
mrsmoos
Jul 8, 2008 4:18 PM
