Temp Gaug not working_ Another instrument cluster
Temp gaug stopped working on Equinox 08.
I want to order an instrument cluster from junkyard with the same ID
Will it just be a plug and play
or it will need to be reporgrammed???
Thanks
Thanks
Are you sure its the cluster? Does the cluster do a gauge sweep on start up for this model?
Not sure if a used cluster needs programming to function. I would program it regardless.
Not programming it should not disable the car as immobilizer functions are not cluster related. A new cluster will lock out the cluster if driven and not programmed.
