Last edit by: IB Advertising
Browse all: Interior
- Chevrolet Silverado 1999-2006 GMT800 Why Are Gauges Malfunctioning?
Guide to diangnose trouble and recommended solutions.
Temp Gauge Not Working 07 Nox
i have a 2007 chevy equinox my fans are not turning on i checked all fuses and relays they all are good what would be the next step for me to check the ac works fine when im driving a soon i come to a stop it gets warm and the do not turn on please help.
You should have started a new thread. Your issue has nothing to do with the the issue that is addressd in this thread. To answer your questions, the first thing I would do is unplug both fans and inspect the plugs for corrosion or other degradation. A common problem on the Equinox is that the plugs going to the cooling fans develop a bad connection over time which eventually causes excessive heat and warps the plug. It can get bad enough that the fans won't work because the current can't pass through the weak connection.
I too have an 07 Equinox with a faulty reading Temp gauge. The needle is all the way over to the right side of the gauge, opposite of where it should be. I replaced the ECT sensor trying to fix the cooling fan problem which turned out to be the fan connector being loose. Now there is a low popping type noise coming from the back part of the engine. Has anyone had this popping noise problem?
See my previous post. I would definitely try replacing the coolant temp sensor before replacing the cluster. An OEM coolant temp sensor for your car is GM p/n 12608814 and runs about $30 from your local stealership. You can also use Wells p/n SU112 which runs about $22 from your local AutoZone, but you will need the part number as the parts guy will not be able to look it up. However, that OEM p/n 12608814 does cross reference to SU112 so it is correct.
This part should take less then 10 minutes to replace, and it is it cheap enough that it is worth a shot.
Good luck
Good luck
It probably is the problem, but I can't guarantee that without further troubleshooting & testing. You can just replace the sensor if you want because they are really cheap and usually not hard to replace.
Good luck
Good luck
