09 express reverse lights.
Hey guys. New guy here wondering if anybody could help me out.
I have a 09 chevy express school bus that failed inspection because the rear lights were not 7 inches round. Soooo... think this would be an easy task for my guy I have him install the correct lights.
He screwed up on the reverse lights " Wired them backwards" So we corrected the wiring and triple checked the fuses under the hood and overhead the drivers seat and natta.
Is there any other fuse location from the factory? I've searched under the dash and found nothing and I really need to get this thing thru dot.
Thanks in advance.
Thanks in advance.
Welcome to the forum. The fuses and fuse blocks should be in the owner's manual available at Chevrolet Owner Manuals - Factory Warranty, features and options, and maintenance explained.
Thank you for your info. But I already found it. Weird spot but whatever I was just coming back to this thread to tell you guys I found the problem so if somebody else comes across the same issue hears the answer.
grayghostss
Express & G-Series Vans
January 25th, 2021 11:12 AM
tokillamurderer
August 21st, 2011 8:09 PM
jeff456
July 15th, 2011 8:03 PM
