1995 G20 lower control arms
Old October 4th, 2017, 12:37 PM
Newly Registered
95G20's Avatar
Default 1995 G20 lower control arms
Where can I find lower control arms for my 1995 G20 van? They are no longer produced.
Can I use a G10 arm? Or an arm from a pick-up?
Old October 4th, 2017, 5:40 PM
Twscarp's Avatar
Try Car-Part.com Used Auto Parts Market.
Car-Part.com--Used Auto Parts Market
Old October 7th, 2017, 2:43 AM
Paul Fuller's Avatar
1973-1980 C series pickup control arms will work.
Old October 7th, 2017, 7:19 AM
Twscarp's Avatar
Can I respectfully ask how you know their compatibility, and where can they be found?
Old October 8th, 2017, 3:52 PM
Chevy built the front end with C series front end parts, check the part numbers for ball joints, bushings, upper control arm assemblies all are the same for corresponding parts between C and G series. A simple research on rockauto.com and you can see the numbers match. The cross member, idler arm, pitman arm, and tie rod assemblies are different.
I have a link somewhere are cross over front parts from a van forum somewhere if I find it I will post. Here is a ink to Summit for lower control arms for C20 pickup. https://goo.gl/HXEzER here is listing for C10: https://goo.gl/cGXyFK
You can research if the C20 fits the G20. I do know that the C10 fits the G10. I just ordered a bunch of front end parts for my G10, all fit.
Old October 8th, 2017, 3:56 PM
Also ebay for a pair.
https://goo.gl/SFCuV6
Old October 9th, 2017, 10:03 AM
Twscarp's Avatar
Assured compatibility is very elusive, why the manufactures wouldn't include the full range of models and years makes me skeptical, but thanks for the info.
Old October 9th, 2017, 11:22 AM
StanVan's Avatar
Rock Auto sometimes has a button for inter-species compatibility. But as a former parts guy(motorcycle), a part number is not exclusive to any model. Honda's parts numbering system tells you the model that the part was originally designed for, but it can show up anywhere, even a car part on a bike(or vice versa).
Old November 16th, 2017, 12:41 PM
cablesplicer's Avatar
I got my 87 g30 upper / lower control arms from rockauto , much cheeper then advance / auto zone and in the ''info'' button it showed all models it fit. Mine is a bucket van and is 9500 lb.'s empty [the suspension and rear axle have been upgraded ]and i have had no troubles with them . I also added new springs from them at the same time. I hope this helps and good luck.
Old March 18th, 2018, 2:14 AM
ThroatwarblerMangrove's Avatar
My parts book indicates the 1992 G-10 and G-20 lower control arms are the same. 1995 SHOULD be the same as 1992.
If it helps: RH GM 15594134
LH GM 15594135
