1998 Chevy Express 2nd Battery Installation
#31
What is your shopping list
The second battery is a deep cycle battery that exclusively runs the van's entertainment system. That system includes a 1000W inverter that runs a TV, BluRay, gaming system, etc. The inverter can also run other appliances that require "house power" (120VAC). Having a second battery on a battery isolator allows key-off use of the entertainment system without the risk of draining the van's starter battery. Hope this helps.
#32
part price qty
a manual reset 150 amp circuit breaker $16.99 3
b soundbox 0 gauge red 1/0 wire 25 feet $28.95 1
c stinger sgp32 200 amp battery relay isolator and relay $43.76 1
d blue sea systems ato/atc fuse block (4-circ w/cover) $19.99 1
e installgear in-line agu fuse holder with 80 amp fuse $6.53 2
f pac pac-80 80-amp relay battery isolator $14.67 1
g upg 12v 100ah deep cycle vrla battery $179.99 1
h qc 3.0 usb charger socket panel $16.87 2
i qc 3.0 dual usb charger socket panel $22.99 1
i also used two sets of installgear 0/4/8/10 gauge battery terminals ($17.95), one feature that attracted me to these battery terminals is that they don't need terminal lugs crimped onto the wires. The 150a circuit breakers are the same way.
