2000 Express 3500 front end upgrade
Hi all,
I just purchased a 2000 Express 3500 with only 24k miles. I’ve looked around and seen some conflicting post about front end conversions. Do I have any options to upgrade to a newer/different models front end? Thank you
Weldtec Designs will sell you a kit to convert to the 2004+ front end.
https://weldtecdesigns.com/product-c...ension/ref/33/
Are you talking about the front end suspension or the headlight grille from a sealed beam type headlight to a headlight composite type? Pretty sure you can swap 2003 - 2019 models, so no (a 2000 Express will not swap) if that was your question.
Check this video :
Composite headlight conversion: 03-19 Chevy Express / GMC Van, Box truck, RV Savana Front end swap
https://www.youtube.com/watch?v=P50bbaoGce4
There are no reasonable options for changing the front clip, the newer clip is much longer and coincides with the longer redesigned from frame section that came in 03. I did this mod, but I also used a newer frame that I had built seperately when designing/building my 4x4 conversion...even with the new frame it was a lot of work. My recommendation would be just to buy a newer van..
narcah
Express & G-Series Vans
October 8th, 2012 4:34 AM
