2003 Express ABS
#11
Professional Mechanic
I did a little more reading since you got me pointed in the direction of the sensors and am going to check them for rust and dirt. There could very well be a rust issue since I don't drive it very often and some times it sits on the lawn for a couple days at a time. As soon as I can get the garage empty I'll get it done and let you know the results. If that doesn't fix it, I'll have to pay somebody to hook it up to a diagnostic computer.
Good luck!
#12
OK. I found the problem. The left front speed sensor is messed up and the ABS light now stays on all the time but the brakes work like there isn't an ABS system which suits me just fine. I never liked ABS anyhow and I'll let the next owner worry about it. That is, after I have it for another six years. The problem is called premature application and is common where there is a lot of road salt used. I found the information on the internet and it described how to clean the rust off the sensor mounting area to solve the problem. It didn't describe how to remove and replace the sensor without breaking it, but like I said, I never liked the ABS and don't mind having the light on.
Kenny
Kenny
juanesq
Express & G-Series Vans
January 1st, 2015 7:54 PM
daplumma
August 24th, 2013 10:17 PM
ShawnInDallas
February 27th, 2010 8:18 AM
