2009 chevy express 2500 code p0171
Old December 13th, 2023, 6:25 PM
  #21
Originally Posted by Idkchevy1234
Can this be done wit any obd reader ?
None of the steps in the link I posted mention a reader.
But the reader can help you measure temperatures.
will it has to be under 10 percent ?
if it gets below 10% it's time to hit the gas station
Old December 13th, 2023, 6:28 PM
  #22
code p0171 and p0174
OK so really this is all part of your other thread. I'm going to merge them for you.
Idkchevy1234 (December 13th, 2023)
Old December 13th, 2023, 6:31 PM
  #23
Idkchevy1234's Avatar
ok so fuel input means the gas percentage on the tank I thought it was the percentage of fuel been used or thrown by the pcv selenoid
Old December 13th, 2023, 6:34 PM
  #24
I don't think there is a such thing as a PCV "solenoid". The PCV sytem has nothing to do with fuel. It vents engine block pressure.
You're probably thinking of vent or purge solenoid valves, which are for the fuel tank and system.
Old December 13th, 2023, 6:36 PM
  #25
yes my mistake purge selenoid sorry
Old December 13th, 2023, 6:39 PM
  #26
Yeah a "level" is the height of a fluid.
Follow the steps Gumby gave you.
Old December 14th, 2023, 12:05 PM
  #27
hello what is a normal evap pressure reading on a obd I'm having -1026 pa reading on the evap system vapor pressure
Old December 14th, 2023, 2:34 PM
  #28
Triaged's Avatar
Old December 14th, 2023, 3:17 PM
  #29
Yea I have a leak somewhere in the evap system
Old December 14th, 2023, 4:40 PM
  #30
what's the diagnostic code?
look it up on obd-codes.com and follow the instructions there.
test the vent and purge valves, and smoke test the system.
Quick Reply: 2009 chevy express 2500 code p0171
