2014 4500 express hard to start
my 2014 chevy 4500 express is hard to start once running it does fine , starts right up . If I let it sit for a day or more it does not want to start , after several tries and 5 minutes it will start most of the time. Runs fine once started no problems. no check engine lights.
I believe I found the problem the fuel pump relay was rusty I replaced it. I am going to let it sit for a few days then see if it starts , I hope this is the problem lot easier than fuel pump. Thanks
Welcome to the Chevy Forums.
After 5 years or so, I begin to suspect balky primary cables. Start by replacing your negative battery cable, and your engine to firewall ground-strap. Corrosion and verdigris create a very hard start
condition. Especially in humid climates.
