Air-conditioning clutch keeps burning up? why?? 1994 Chevy G30 cut away 5.7
Old September 6th, 2017, 9:12 PM
jbbcd's Avatar
Default Air-conditioning clutch keeps burning up? why?? 1994 Chevy G30 cut away 5.7
on my 3rd air conditioning clutch, probably getting less than 1000 miles B4 cluch blows apart. have also installed new pumps too...
Whats wrong here?
Thanks
Old September 7th, 2017, 12:08 AM
canucklehead's Avatar
Belt too tight? That will roast the bearings.
Old September 7th, 2017, 5:58 AM
jbbcd's Avatar
single belt drive, the clutchs have been burning literally off the pully. (face plate of the clutch)
Old September 7th, 2017, 9:52 PM
Some good thoughts in this thread....
Why do I keep burning up A/C clutches - Chevelle Tech
Old September 9th, 2017, 8:55 AM
jbbcd's Avatar
thanks for all the replies... hopefully I get it fixed correctly...
Old October 7th, 2017, 3:26 PM
Chad Douglas's Avatar
Did you check/adjust the air gap? I don't know the spec for these compressors, but if the air gap is a little too big or the magnet behind the idler is weak, it will cause slippage, and cause it to burn up.
