battery keeps draining
Old November 20th, 2006, 2:49 PM
dogz46's Avatar
Default battery keeps draining
new battery new alt took of starter bench tested it its fine cleaned every connection i possible could. ive been told by the last owners they were told to change starter because they were bad for killing batterys because of poor ground design,also cant figure out why the wippers always swipe (only once)when i turn the key to on possition. this is a 83 van 20 5.0 liter camper pw,ps,pb,a/c etc. thanks in advance for your opinion.
Old November 20th, 2006, 3:34 PM
golfer's Avatar
Default RE: battery keeps draining
https://chevroletforum.com/m_11221/tm.htm
Check out the above proceedure, you won't have to worry about the modern CPU's in the '83.
av8rkirk
November 10th, 2015 7:28 PM
Matts10
November 5th, 2010 8:19 PM
duscarter
Silverado & Fullsize Pick-ups
March 30th, 2008 8:59 AM
silverado99
January 21st, 2008 12:35 PM
chevythunder
August 7th, 2007 2:36 AM
Quick Reply: battery keeps draining
