Excessive outside wear on solid rear axle?
Old January 23rd, 2021 | 7:05 PM
sumner_nick's Avatar
Default Excessive outside wear on solid rear axle?
Hey everyone! I am hoping to hear some thoughts on a very strange issue I am having with my 1990 Chevy G20. I recently, 6 months ago, replaced all 4 tires due to considerable outside wear on the rear tires. A few months later, and I am encountering again very significant wear on the OUTSIDE of the rear tires only. Front tires are completely fine, and wearing evenly. I have visually inspected for camber on the rear thinking they probably have positive camber, when in fact they are actually NEGATIVELY cambered a bit. Not sure what to make of this, as there is really no camber adjustement for the rear due tot he solid axle. I am stumped as to the excessive outside tire wear especially due to the negative camber. Any thoughts are greatly appreciated!
Old January 23rd, 2021 | 7:26 PM
oh man those look really bad
sumner_nick (January 23rd, 2021)
Old January 23rd, 2021 | 7:37 PM
Triaged's Avatar
Measure the toe. Toe wears tires faster than camber. Yes you might have bad axle bearings but you might also have a bent axle housing.
Old January 23rd, 2021 | 7:53 PM
Ill do that, thanks for the response! Would something like a rear end collision potentially cause the problems I am seeing? Also, is it possible for the axle housing to be bent enough to cause this amount of difference in wear and still have it drive normally? I have not felt anything concerning when driving.
Old January 23rd, 2021 | 7:54 PM
Thanks for the response! I will check the wheel bearings.
Old January 23rd, 2021 | 10:55 PM
Triaged's Avatar
A collision could bend the axle housing. They are very big but not indestructible. I've broken one myself on my K5 driving like an idiot off-road. You could take it to an alignment shop and have them do a 4 wheel alignment but other than bearings there isn't really much you can do other than replace the axle assembly. If it is bent enough to wear the tires that quick I think you could measure it with simple tools.
Old January 24th, 2021 | 9:51 AM
This!!!! get a wheel alignment. the best way to confirm if something is bent or out of spec.
Rednucleus (January 24th, 2021)
Old January 27th, 2021 | 9:13 PM
I measure the toe, and idk if there is a correct conversion to use, but it measured 68.125” in the rear, and 67” in the front of the rear tires. Over an inch difference so definitely very toed in... what can I do about this?
Old January 27th, 2021 | 10:43 PM
Triaged's Avatar
That is a boat load of toe in! Time to go to a wrecking yard and pick up a new rear end to swap in. Can't be a truck axle. They are narrower than van axles.
Old January 27th, 2021 | 10:47 PM
well I was hoping for something easier, but fortunately there’s not a whole lot going on down there in the rear end. Thanks for all the help!
Quick Reply: Excessive outside wear on solid rear axle?
