Express2500 4.8l low compression
Today my express started to misfire on multiple cylinders primarily #6 and # 8 so I checked the compression and had 0psi of compression in cylinder 6. My engine only has 210000 miles. Are these engines that ****ty I thought the last was suppose to be very reliable. My question is are the valves know to prematurely fail ?
I would never buy a 3/4t van with a 4.8L engine.
Kael (November 17th, 2020)
possible camshaft problem also. what were the compression numbers on the other cylinders?
the next possible steps imo would be:
-leak down test to determine where the loss is from,,,,intake, exhaust, headgasket, rings
-vacuum gauge to see if its a valve problem
-remove valve cover....crank it over and watch for rocker arm movement
TahoeMatt
11
February 6th, 2012 7:15 PM
