Full heat or full cold - NOTHING in between
Old March 29th, 2024, 3:42 PM
bcpaul's Avatar
Default Full heat or full cold - NOTHING in between
I have a 2006 Savana 3500. The heat control for the front only puts out full heat or full cold, but trying to adjust the **** anything in between does nothing.
Heat and AC works fine, just not able to adjust temperature.
Any ideas?
Old March 29th, 2024, 3:43 PM
that will be a malfunction in either the control panel, or the temperature blend door actuator.
Old March 29th, 2024, 4:08 PM
bcpaul's Avatar
Do you know how to diagnose which one it might be?
Old March 29th, 2024, 4:30 PM
are you good at electrical troubleshooting with a meter and reading diagrams?
Old March 29th, 2024, 6:23 PM
bcpaul's Avatar
Sure. I tested the variable resistor on the heater control ****.
25 ohms to 9200 ohms
Old March 29th, 2024, 6:27 PM
schematics and drawings are on charm.li
Next I would probably look at the actuator and door to see what they're doing when you twiddle the ****. It could be binding up or jumping teeth or something.
MorphsuitHD
November 24th, 2022 11:08 AM
burbanmom
January 31st, 2019 8:42 AM
Renae
December 27th, 2017 8:38 AM
chev96caprice
December 25th, 2011 4:42 PM
kenintally
February 6th, 2011 8:55 AM
Quick Reply: Full heat or full cold - NOTHING in between
