HELP - Some of the under dash wiring fried 2005 Express van
#22
Absolutely it could be only a matter of replacing the bulb.
Glad you sorted it out.
But here is the schematics
#23
Hi
one thing I just learned is that the OBD2 port is powered by the same fuse as the cigar lighter !
so if you pull that fuse your OBD2 reader will not work .....ummm
So I am going to run a fused 12v wire to the pin on the OBD2 plug
Can you post the drawing of the OBD2 plug / pin out
Hopefully I am the only one that has this problem , but at least there is some info for the next guy
