Intermittent rich codes
Old March 7th, 2024, 12:50 PM
StephenN's Avatar
Default Intermittent rich codes
Van dies first start of about 1&2 times a week. Then fires right back up(today I had to crank and feather the gas to get it to start)
Doesn't die again, idles good, maybe a little bit off
Drives good
Intermittent rich codes 172-175 bank 1 and 2 they'll go off and on
Can't find the shrader valve to test fuel pressure. Is it the bright green cap on the driver side on top of the engine? My tester is not getting a reading off that.
Will replace fuel filter
did a AC Delco MAF
Doing plugs
130k on the dash.
2008 5.3l AWD
Any ideas of what I should test?
Old March 7th, 2024, 9:50 PM
Should be. Check charm.li for pressure specs and testing procedure.
Is it flex fuel?
clanofwolves
January 3rd, 2024 5:59 AM
Darc
1988 - 1998 (GMT400)
October 24th, 2019 10:42 PM
jeremy.yeager81
Astro
July 23rd, 2018 8:34 PM
Twisted Noodle
Uplander
November 13th, 2010 8:25 AM
jameseroot
Silverado & Fullsize Pick-ups
December 8th, 2009 9:34 PM
Quick Reply: Intermittent rich codes
