removing black door panels on side/rear cargo doors
#12
those look like pop rivets to me. I would go ahead and drill them out.
#14
https://www.harborfreight.com/45-pie...-kit-1210.html
you'll need to know the hole size to choose the correct insert+fastener. You might try drilling out one rivet first.
#15
GEEZE Did Any one not read what I posted...
YES they are pop rivets... and YES I drilled 1 of mine out
ONLY to find... that it is attached to a door panel clip.... that POPS into
the hole in the door.....
#16
If it wasnt so late I would go out and find the said clip then open my door
and show you all that on my van.... the door panel attaches to the door
its self with clips those clips are POP RIVETED to the door panel
you exert some pressure on the panel and the door panel will
pop off NOW provided that you take that handle assembly off too...
#17
apologies ... I got distracted with all the rivet gun talk.
It makes sense. My passenger van looks a bit different, but yes, a lot of the trim is held by various types of clips, and will come off with a quick, firm tug. Unfortunately, they only survive removal once or twice before they break.
#18
i did read your post and was hoping you were right!! awesome
will pop these off in the next couple of days and insulate the doors too
hopefully they wont need to come off again and will go back together right
thank you!
thank you!
Bruce Koster (October 25th, 2020)
#20
Is that **** on the walls? I get why you call it Elmo now.
