TCM pin inside transmission broke
trying to get the plug into the TCM on the transmission, pin #2 (ground) broke. Anyone have recommendations to fix it rather than buying a new one?
^^^Top left pin
LMM is a 2008-2010, and the LGH is a 2011-2016 Duramax Diesel engines.
L20 and L96 are 4.8 and 6.0 gasoline engines.
Seems like your vehicle doesn't even use that Pin 2. Easiest way to verify is to look on the vehicle side of the connector to see if there's a wire coming in.
