Transmission fluid change & flush torque converter
89' G20 101,000 miles
Fluid looks amber/clear I think its time to drain it?
Will I be able to draw the fluid from the dip stick tube, then run engine to drain torque converter or will I have to drop the trans pan then run engine to the drain torque converter?
Thanks for all your help,
Jim
Jim
Why doing it myself? Here in NJ, PepBoys and 10minute oil change charge 150 dollars and NO pan drop and NO new filter. They draw the T-fluid out from filler tube while engine running to drain some T-fluid from torque converter.
Years ago I watched 10minute change mine for 75 dollars, they had to brace up trans and then remove the cross-member mount of transmission to remove pan. They did not run the engine to loosen some T-fluid from torque converter?
All suggestion are welcome, thank much.
Jim
Jim
Chuck25
October 15th, 2013 11:06 AM
JoeBlow
Silverado & Fullsize Pick-ups
11
April 27th, 2012 11:08 AM
jgray152
July 12th, 2010 8:22 PM
DeHartShadow
March 28th, 2010 10:10 PM
