Washer fluid problems
Hey y’all!
My washer fluid won’t spray and I’m having problems trouble shooting. There’s fluid in the res, I replaced the water pump, and the wipers themselves work perfectly. How should I go about potentially unclogging the lines or seeing if the problem is somewhere else? Thanks in advanced!
1984 Chevy g20 conversion van
did the fluid freeze?
try activating the pump manually
if you don't hear the pump...have someone activate the washers...unplug the electrical connector at the pump...one wire should have battery voltage...the other should show ground.
Derrick71 (March 3rd, 2024)
