What amp alternator comes stock on my van (06 2500 express, passenger)
Old October 25th, 2017, 4:36 PM
AaronColby's Avatar
Default What amp alternator comes stock on my van (06 2500 express, passenger)
So I want to replace the serpentine belt but they are different sizes for the different alternators. I guess the two sizes they list are 105 and 145amps. I've looked up my VIN but different sites are saying different things. I've tried to see if my alternator says anything on it and I couldn't find anything useful. I've got a 2006 Chevy Express 2500 Passenger with rear AC. My VIN is 1GAGG25V861227006
Old October 25th, 2017, 6:42 PM
Twscarp's Avatar
What is your engine size? The VIN Decoder site compnine.com will give you a detailed and very accurate list of your van's build, it will tell you what size alternator you have. They charge $5 to read 5 vin's, highly recommended.
Old October 25th, 2017, 6:46 PM
AaronColby's Avatar
I have a 4.8 liter V8. I did check the comp nine it said something different than another site I'm curious which I should trust
Old October 25th, 2017, 6:54 PM
Twscarp's Avatar
I would trust compnine, free decoders missed a bunch of stuff on my van. If you're going to buy the belt locally, just buy both before you start, return the one you don't use.
Old October 25th, 2017, 11:02 PM
StanVan's Avatar
Does Compnine give the RPO codes? If so, you can double check it with the RPO sticker on the passenger front door.
The decoder here(above, under tools) says you have a 105 amp.
Old October 26th, 2017, 1:53 AM
AaronColby's Avatar
Yeah unfortunately that's what I've seen, compnine says 145, others say 105, yeesh
Old October 26th, 2017, 6:38 AM
Twscarp's Avatar
Yes compnine shows the RPO code, for instance, mine is K68 GENERATOR,105 AMPERE 105 AMP
Old October 26th, 2017, 6:52 AM
Twscarp's Avatar
You mentioned your van has rear A/C, according to the decoder here it says "Alternator, 105 amps (Not available with (C69) Air Conditioning, rear.)
That's telling me you have the 145 amp.
Attached Thumbnails What amp alternator comes stock on my van (06 2500 express, passenger)-screen-shot-2017-10-26-7.45.01-am.png
Old October 26th, 2017, 7:02 AM
Twscarp's Avatar
Another thing, pretty sure you have 2 belts, the serpentine and a separate one for the A/C compressor.
Old October 26th, 2017, 8:28 AM
StanVan's Avatar
Compnine didn't have my VIN.
