03 GMC Savana want a spare drive belt but what alternator?
Old Apr 12, 2026 | 10:25 PM
the Brain's Avatar
Default 03 GMC Savana want a spare drive belt but what alternator?
03 GMC Savana conversion van 5.3 engine.want a spare drive belt but what alternator?
105amp or 145amp? I think the 145amp has a larger case which makes sense to have a longer drive belt. can I decode the vin# to find which alt. my van has?
or can I look at aternator for IIRC this era van was a 244 or something for the 145amp. or can I mearsure the pulley. I'd prefer to not remove the belt just to find the correct length. please advise an thanks
Old Apr 13, 2026 | 12:42 PM
Triaged's Avatar
Look for the RPO code sticker in the door frame (passenger side I think)
Old Apr 18, 2026 | 1:03 PM
loopedr1's Avatar
I’m not sure but I think the pulley on both alternators are the same…so the belt should be the same…not 100% though
Old Apr 20, 2026 | 12:59 PM
Charles J Edward's Avatar
Default What I always do -
For the first belt replacement I buy both belts. Use the one that fits, write it's part number and length in the vehicle log, or in sharpie underside of the hood, and return the one I didn't need. After that I just check my notes.
BTW: Before removing the belt draw out all the pulley, idler, and tensioner locations - AND belt route around them in sharpie or log book.
In your situation - install the new belt now and keep the old belt as the spare. Then you can be Positive it will fit when you need it. <g>
Old Apr 20, 2026 | 8:26 PM
Triaged's Avatar
For what it's worth I have the 145a. Replacement is 2mm shorter than factory and almost too tight to fit.
Lakeman 903
Nov 27, 2021 2:19 PM
BunyonandBabe
Jul 18, 2021 7:46 PM
qualitypro
Aug 7, 2015 9:45 PM
pgabrielfreak
Dec 23, 2012 10:07 AM
Er Au
Aug 12, 2012 10:44 PM
