04 chevy express 3500 radio switched 12volts
Old Apr 2, 2024 | 10:00 PM
the Brain's Avatar
Default 04 chevy express 3500 radio switched 12volts
04 chevy express 3500 radio switched 12volts new radio install.
I've sliced into the oem radio harness' red w/ white tracer for constant 12VDC an the Black for ground. which color wire is the switched 12VDC?
I saw on y-tube a man splicing into the climate control leftist beige wire. I'd prefer to steal from the radio harness.
my new radio has ulimation organe w/ white tracer for dimming the backlight, the express has like 3 organe wires how do I know which to connect to I'd prefer to not trail an error it.
thanks
Old Apr 2, 2024 | 10:02 PM
electrical schematics are available on charm.li
Old Apr 3, 2024 | 9:08 AM
the Brain's Avatar
wow thats a wealth of infor. thanks mountainmanjoe for the link I've saved it definitily can use on other GM stuff.
I navigated though all of it an didn't find or didn't understand how to find. apparently I need to get into power distribution.
here's where I navigated to.in connection ID didn't see the red power wire, or the switched 12VDC I need.
Old Apr 3, 2024 | 9:50 AM
The stereo doesn't have ignition switched 12V.
It gets woken up by special message on the class 2 serial data communication network.
Old Apr 3, 2024 | 2:14 PM
the Brain's Avatar
will steal from the ac/heat blower here
thanks mountainmanjoe will report back w/ new audio sys.
Old Apr 3, 2024 | 3:00 PM
hopefully you don't overload that circuit
Old Apr 3, 2024 | 4:26 PM
the Brain's Avatar
ok I'm not taking the chance on over loading the blower
plan B was to look inside the fuse block under driver seat which requires removing the whole dam seat.
plan C connect though the firewall to the battery idolater which mite ruin the isolator. I do see a rubber gromit on driver firewall near parking brake but it's tight from uptop maybe accessible from underneath.
plan D use the same constant 12VDC from radio an branch off it w/ my own manual switch.
Old Apr 3, 2024 | 5:45 PM
the seat is just 4 nuts. No biggy.
instead of a switch, use a relay energized by the HVAC
Old Apr 3, 2024 | 5:52 PM
the Brain's Avatar
I've never connected a relay I know it has 4 posts this mite be a tad to conplicated for me.
don't want to mess w/ removing the seat. leaning toward plan D
Old Apr 3, 2024 | 6:16 PM
except the one day you'll forget to switch it off and get stranded in the middle of nowhere
