06 express 3500 6.0 misfiring
Old Apr 13, 2012 | 9:28 PM
captcave's Avatar
Default 06 express 3500 6.0 misfiring
I've got a 6.0l truck that has started a habit of misfiring if you let it idle for more than 20 secs or so. Once it starts, it will eventually stop if you get above 40mph.
06 express 3500 6.0l
47,xxx miles
codes:
P0053: Unknown code - More information may be available on the web
P0132: O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0135: O2 Sensor Heater Circuit (Bank 1 Sensor 1)
P0300: Random/Multiple Cylinder Misfire Detected
Freeze Frame data
Engine Load = 26.275 %
Engine Coolant Temperature = 75 °C
Fuel Trim Bank 1 Short Term = -35.156 % (do those look right?)
Fuel Trim Bank 1 Long Term = -19.531 %
Fuel Trim Bank 2 Short Term = 7.031 %
Fuel Trim Bank 2 Long Term = 3.906 %
Intake Manifold Pressure = 6.092 psi
Engine RPM = 647.25 rpm
Speed (OBD) = 27 km/h
Timing Advance = 16 °
Intake Air Temperature = 36 °
CMass Air Flow Rate = 74.438 cfm
Throttle Position(Manifold) = 0 %
From what I can gather, I need to:
Check for vac leaks
check the upstream driver side o2 sensor/wiring
possibly replace that sensor.
Anything else I should check, or be looking for.
Old Apr 13, 2012 | 11:00 PM
EinST's Avatar
Welcome to the forum. I think you're on the right track. I don't think there's vacuum leak, though. P0053 means heater resistance out of range on bank 1, sensor 1. It sounds like the sensor signal circuit is shorted high to the heater circuit. High sensor voltage translates to rich condition and thus the ECM reduced the the fuel on bank 1. Too little fuel then caused P0300, probably all on bank 1, i.e., odd numbered cylinders.
Old Apr 14, 2012 | 9:04 PM
captcave's Avatar
I changed the sensor today. Drove a couple miles and then let it idle for about 30 mins. So far so good.
Monday I'll probably find out for sure.
Thanks
Old Apr 21, 2012 | 6:18 PM
captcave's Avatar
So far, a week later, no misfiring, no codes.
Thanks
Old Apr 22, 2012 | 3:03 PM
EinST's Avatar
Congrats and thanks for the update.
MWRacing
Jan 21, 2015 10:08 PM
glkirk
Mar 5, 2008 2:46 AM
ditto1
Jun 28, 2007 11:22 PM
hawk265
Sep 27, 2006 3:07 PM
