09 express reverse lights.
Old Mar 31, 2011 | 3:42 PM
CTshop's Avatar
Default 09 express reverse lights.
Hey guys. New guy here wondering if anybody could help me out.
I have a 09 chevy express school bus that failed inspection because the rear lights were not 7 inches round. Soooo... think this would be an easy task for my guy I have him install the correct lights.
He screwed up on the reverse lights " Wired them backwards" So we corrected the wiring and triple checked the fuses under the hood and overhead the drivers seat and natta.
Is there any other fuse location from the factory? I've searched under the dash and found nothing and I really need to get this thing thru dot.
Thanks in advance.
Old Mar 31, 2011 | 5:41 PM
EinST's Avatar
Welcome to the forum. The fuses and fuse blocks should be in the owner's manual available at Chevrolet Owner Manuals - Factory Warranty, features and options, and maintenance explained.
Old Apr 1, 2011 | 9:12 AM
the reverse light fuse is located in the body fuse block located below the drivers seat. It is fuse 15 labelled t/lamp bck/up and is a 10 amp fuse.
Old Apr 8, 2011 | 3:59 PM
CTshop's Avatar
Thank you for your info. But I already found it. Weird spot but whatever I was just coming back to this thread to tell you guys I found the problem so if somebody else comes across the same issue hears the answer.
grayghostss
Jan 25, 2021 11:12 AM
tokillamurderer
Aug 21, 2011 8:09 PM
jeff456
Jul 15, 2011 8:03 PM
d1nonly34
Apr 2, 2009 11:14 AM
myCHEVYkicksass
Nov 21, 2006 12:11 PM
