+12V ignition hot? Equivalent of the plug-in accessory harness that the trucks have?
Old Jun 16, 2023 | 9:32 PM
rehoboth's Avatar
Default +12V ignition hot? Equivalent of the plug-in accessory harness that the trucks have?
Hello everyone!
We are working on our "new to us" '06 Savana 3500 6.0 15-passenger van, and we'd like to be able to add a few accessories. GM full-size trucks from this same time-frame have an accessory harness you can simply plug in, to wire up whatever add-ons your heart desires. I've searched and searched, but can't find anything similar for the van. Was this a truck-only thing?
Assuming that the solution isn't that easy, what choices do I have for a 12 volt ignition-hot (doesn't stay on with the van off) line? I'm fine with either RAP, turning off 20 minutes after you turn off the van, or plain old ignition-hot, turning off immediately when I turn the van off. Would strongly prefer not to splice into wires, I've had enough old cars with wiring hacked up for stereos, alarms, etc that I try to keep my wiring as clean as I can. We are able to make a proper tap, i.e., a wire meant to go between a male and female connector, having a matching connector for each end but splitting into two wires to provide the connection I need... but where to put it? I'd like it to support at least 10 amps of current. Historically we would have used the cigarette lighters, but on the van, the lighter is always hot - I have to unplug my phone charger when I park, or it will stay on indefinitely.
The GM Upfitter site seems to suggest in its wiring diagrams that there are plugs I can plug into with a harness I'd need to make myself - but does a van not intended for an upfitter have the same wiring harness as one that is?
It's an LS, so power windows and power locks, but no (i.e.) rear defroster. Speaking of which - any way I could tap into that circuit? I'm assuming GM made the defroster only run with the power on.
Thanks in advance!
Old Jun 16, 2023 | 10:19 PM
run your own fused circuit and switch it with a relay energized by a RAP accessory. HVAC for instance.
Mike Moore
Jan 21, 2021 11:46 AM
ChevyVanMan
Apr 26, 2017 4:38 PM
Ajdsaint@gmail.com
Sep 19, 2016 7:50 AM
Ajdsaint@gmail.com
Sep 14, 2016 8:25 AM
wgander
Aug 10, 2016 12:03 PM
