1985 G30 Stereo Install
Old May 16, 2014 | 10:12 AM
TyrannicalTy's Avatar
Default 1985 G30 Stereo Install
Hello all,
This is probably a topic that has been covered many times, but I am replacing the old analog, dial-**** radio/cassette stereo head unit in my 1985 G30 motorhome with a newer Eclipse CD2000 that I had lying around. I wanted to share some info and get opinions.
Last night I pulled the old head unit. I have the 3-plug wire harness pictured, but no 4th plug for "(M) 12V Battery Wire." This makes sense to me, since a dial-**** radio and cassette player wouldn't need constant voltage to remember any particular settings (i.e. station presets, clock, CD track, etc.)
Any newer head unit is going to have a 12V ignition hook-up, which turns the unit on and off with the vehicle ignition, as well as a 12V battery hook-up which will remember the presets mentioned above. I could combine the battery and ignition wire at the harness, but am I correct that the proper way would be to run a new wire to something that is always "hot" in the fuse box?
I think it may also be a good idea to add an in-line fuse to this new battery wire. Any ideas/suggestions? Anyone do this already?
Attached Thumbnails 1985 G30 Stereo Install-stereo-install.jpg   1985 G30 Stereo Install-head-unit-battery-wire.jpg
Old May 16, 2014 | 10:38 PM
canucklehead's Avatar
Just run to fuse box or to cig lighter wire. Its only half an amp for that memory wire so you won't overload anything you tie into.
Old May 20, 2014 | 9:07 AM
Hi Canucklehead,
Thanks again for your responses. Is the Cig lighter always hot in an older vehicle? I know in my cars, the power is cut when the ignition is off. Having a hot wire right there would definitely be the easiest solution. However, running a wire to a fuse tap would be no big deal assuming the fuse panel is always hot.
Regards,
Ty
davet
Feb 17, 2022 8:08 PM
TyrannicalTy
Aug 10, 2020 5:24 AM
Joexsmoot
Aug 1, 2015 4:09 PM
Dracutchef
May 30, 2015 5:22 PM
