1986 g20 van no spark to plugs???
Did you pull the dist cap and check the rotor for arced or corroded contacts? Maybe there is grounding somewhere in the cap, perhaps if its cracked.
Is the dist drive shaft turning? Turn the engine over a bit with the cap off.
overdrive87
June 29th, 2014 11:00 PM
93ChevyVan
December 22nd, 2013 10:24 PM
