1988 Gmc 1500 700r4 troubles
Old Mar 6, 2011 | 1:11 PM
kanatuna97's Avatar
Default 1988 Gmc 1500 700r4 troubles
Hello all this is my first post here but really need some help,When driving in 4th gear at 60-70 kms i floor it to get passing gear it feels like it goes into neutral when i let up on throttle it goes bang when it reconnects nasty really.
UPDATE the doesnt do this all the time seems like when im floor it.
Thanks all your help.
ADJUSTED TV CABLE WAS LOOSE
Old Mar 9, 2011 | 10:32 PM
atransmission's Avatar
I know you don't want this reply but you asked....... any time a transmission goes "bang" it's never a good thing. it sounds like you have a internal problem, might be a broken sprag or split drum...... I would drop th pan and see if you have anything in the pan....... Hope this helps
http://atransmission.info
http://700r4.info
Old Mar 10, 2011 | 8:14 AM
kanatuna97's Avatar
Thanks the bang was caused by the high rpms,when it kicked back into gear,I adjusted the TV cable and wow what a diffference in shifting and it down shifts flawlesssly at this time.I guess time will tell
Old Mar 18, 2011 | 1:27 AM
anjy834u's Avatar
great..i thought u mind need a gearbox change.
Old Mar 18, 2011 | 8:08 AM
kanatuna97's Avatar
Yaaa i was hoping nothing went wrong sorrry to doubt your words here its toast,cratered,scrap.thanks for your help
Justin Bent
Mar 5, 2013 1:44 PM
Mathius
Oct 19, 2011 11:47 AM
gnomepunter
Mar 30, 2010 7:07 PM
jshafer
Jan 6, 2010 3:59 AM
Chevro_Runna
Mar 21, 2009 10:27 AM
