1989 G30 Fleetwood Conversion battery Cables
Old May 22, 2022 | 8:41 AM
TexasST's Avatar
Default 1989 G30 Fleetwood Conversion battery Cables
Hi, I’m puzzled with my battery wiring which has been hacked about.
the truck has the starter battery and a leisure battery, and the cabling makes no sense (to me!),
the battery + side has a Black cable going to the starter motor & a smaller Red wire to the junction box on the bulkhead (behind the battery) I’m assuming that the black cable should should be red and whoever did the wiring only had black cable.
But On the - side of the battery i have a Red cable going to a battery parallel solenoid see Pictures, and a Black wire going to the earth point on the engine block.
my question is, does this sound / look correct? As i don’t understand how it appears to be that a negative connection is going to a positive connection on the solenoid.
Any help would be much appre
Battery Parallel Solenoid fed from the Negative side if the battery.
Negative battery connection, black to engine block, red to battery solenoid
Positive battery connection
Old May 25, 2022 | 1:13 AM
William Kisselstein's Avatar
That red cable is probably a replacement as it looks pretty poorly installed. These vans had side post terminals from the factory.
dberladyn
43
Jun 24, 2020 5:06 PM
pickledcherrypepper
Mar 3, 2017 12:10 PM
jdbruegge
Apr 4, 2014 7:31 PM
jason.t.h
Jun 1, 2010 3:04 AM
chevydig
Cobalt
Sep 4, 2008 5:23 PM
