1991 G 20 power window problem
Old Sep 6, 2021 | 11:45 AM
Olegee's Avatar
Default 1991 G 20 power window problem
My passenger door window started making loud noise when window reached closed position. Then started making it when putting window down. I have left window up afraid it would quit entirely. Now experiencing problem with driver's door also. Anybody experience this?
Old Sep 15, 2021 | 1:10 AM
William Kisselstein's Avatar
You'll have to do some diagnosis to determine if the motor is failing or the mechanism has problems. Take the cover off the door and have a look inside.
The motors aren't hard to change but be wary of the spring in the regulator, it's easy to pinch your fingers.
As a bonus, if you have to look for used, squarebody Suburban rear door motors are the same however reversed side for side - my 1991 van got a 1986 Suburban drivers side rear door motor in it's passenger front door. Worked fine.
Old Sep 19, 2021 | 3:40 PM
johnt365's Avatar
Not sure if you already fixed it but I had this on my 95 recently.
The bolts for the motor are covered so I made some cuts to help access them. Was much easier after that
Old Sep 20, 2021 | 12:19 PM
I had no problem with this. You take the regulator out to change the motor.
justin69
Feb 28, 2015 2:54 PM
highroad
Dec 6, 2014 11:18 AM
gates62
May 10, 2010 3:57 PM
pose_master
May 2, 2010 1:23 AM
techcons
Dec 31, 2007 1:23 PM
