1994 G20 Conversion van - Shocks question
Old Mar 13, 2017 | 3:01 PM
Max Vaysburg's Avatar
Default 1994 G20 Conversion van - Shocks question
Hello all,
Just got a 1994 G20 conversion van. The ride is soft but get seriously bumpy on imperfections. I think it's time change the shocks. What are the specs on front and rear?Looking to go with Bilsteins but not sure if front and read are the same or not.
Thanks!
Max
Old Mar 14, 2017 | 7:01 AM
Twscarp's Avatar
I would go with Monroe Gas-Magnum 34839/front, 34910/rear, check your actual specs, RockAuto.com has a large selection, reasonably priced.
The Monroe® Gas-Magnum® truck shock absorber is designed for mid to full size, hard working pick-up trucks and vans. These units provide firm control without a harsh ride. With up to twice the fluid capacity of standard 1 inch bore shocks, Monroe® Gas-Magnum® truck shocks work more efficiently with less effort.
Plus they have a rebate available now. Receive up to $100 with purchase of qualifying Monroe or Rancho Shocks or Struts. Your application would receive the $50 Visa Prepaid Card.
Get a $50 Visa Prepaid Card with purchase of four (4) qualifying Monroe or Rancho shocks.
Get a $75 Visa Prepaid Card with purchase of two (2) qualifying Monroe shocks and two (2) qualifying Monroe struts.
Get a $100 Visa Prepaid Card with purchase of four (4) qualifying Monroe struts.
Old Mar 14, 2017 | 8:31 AM
Thanks! I never used Monroe before. Have you had good experience with it? Price is low enough to not make such a dent in my pocket.
Old Mar 14, 2017 | 9:00 AM
Twscarp's Avatar
Yes, very good shock, probably most used and trusted worldwide.
Old Mar 19, 2017 | 7:23 PM
greenfire's Avatar
Check out your springs too. They affect ride more so than shocks.
Old Mar 3, 2020 | 12:10 PM
ray caldwell's Avatar
Unfortunately I cant agree with the rest of the world. Monroe,didn't even bother after one had a leak when I pulled it out of box. Bilstein, seemed way too wimpy for loaded van. But rancho. Actually broke lower mounts the po half welded on. And can you beat a lifetime warranty? Only thing I've seen tougher are the Gabriels I put on my freightliner
