1995 Chevy G20 Rear Door Glass
Old Dec 10, 2021 | 2:25 PM
mossyback's Avatar
New User
Awaiting E-mail Confirmation
Default 1995 Chevy G20 Rear Door Glass
I need the driver's side rear door glass (factory tint) for my van. Could someone recommend a source for this glass? Many thanks!
Old Dec 15, 2021 | 3:06 PM
William Kisselstein's Avatar
Salvage yard, eBay, etc. The vented swing out is an easy swap if you don't have it already.
Old Dec 15, 2021 | 4:13 PM
mossyback's Avatar
New User
William, thank you for the reply. My van does not have the swing out window, it has the solid pane of glass in each rear door. Are you saying that the swing out window is the same size and will fit within my frame and rubber seal ?
Old Dec 19, 2021 | 4:27 AM
If you have access to a donor van, remove everything. It replaces the fixed window and seal entirely. You will have to drill a few holes but IIRC the bolts are self-tapping. It's much easier to install the swing-out than to work the gasket back into place.
I did the swap on a short side door some years ago, it wasn't hard.
Old Jan 22, 2022 | 11:19 PM
jimmydriver's Avatar
I changed all of mine.
Mike44134
Jan 8, 2017 4:15 PM
Edptune@aol.com
Jul 30, 2015 5:01 PM
johntalley
Mar 7, 2015 11:23 PM
AdamY
Nov 5, 2014 7:00 AM
graybeard47
Sep 5, 2013 6:24 PM
