1995 G20 lower control arms
Old Jul 22, 2018 | 10:16 AM
  #11
habanerored52's Avatar
Default Compatibility
Originally Posted by ThroatwarblerMangrove
My parts book indicates the 1992 G-10 and G-20 lower control arms are the same. 1995 SHOULD be the same as 1992.
If it helps: RH GM 15594134
LH GM 15594135
do you think the lower would also fit my 1987 G20 ?
Old Jul 22, 2018 | 10:19 AM
  #12
Originally Posted by Paul Fuller
Chevy built the front end with C series front end parts, check the part numbers for ball joints, bushings, upper control arm assemblies all are the same for corresponding parts between C and G series. A simple research on rockauto.com and you can see the numbers match. The cross member, idler arm, pitman arm, and tie rod assemblies are different.
I have a link somewhere are cross over front parts from a van forum somewhere if I find it I will post. Here is a ink to Summit for lower control arms for C20 pickup. https://goo.gl/HXEzER here is listing for C10: https://goo.gl/cGXyFK
You can research if the C20 fits the G20. I do know that the C10 fits the G10. I just ordered a bunch of front end parts for my G10, all fit.
are you positive? I thought the C series would interchange but never found anyone who could tell me for sure.
Old Jul 22, 2018 | 10:51 AM
  #13
Twscarp's Avatar
My suggestion would be, go to the Rock Auto site and order a C20 one, and see if it matches yours. If not the same send it back.
