1996 Chevy G10 - Odd Brake LIght and Driveability Issues
Old Oct 7, 2017 | 4:15 PM
Fortran's Avatar
Default 1996 Chevy G10 - Odd Brake LIght and Driveability Issues
I have a 96 Chevy G10 van with 14x,xxx miles. It has a 5.0 engine.
Recently, it has been given me a whole host of problems. However, I doubt they are all the result of a single issue. My largest concern is with a recent issue that appears related to the braking system.
I noticed the issue first about several weeks ago. I was pulling into a turning lane when the van appeared to pull/buck/surge and I believe the both the Brake and ABS light came on. As I was actually turning, this sympton repeated itself, though I cannot be positive both lights came on.
I had not been driving the van due to the issues it had been have having, but, after performing another repair, I decided to try and drive it again. This time, while I was doing ~70mph on the interstate, the van essentially repeated the symtpons noted in the preceding paragraph - it bucked/pulled/jumped (I am not sure how to describe it), the speedometer fluttered, and at least one brake light (either the normal or ABS) briefly came one.
Again, I have not been driving it, but I went to test drive this morning. This time, I did not even fully pull out before the issues started. This time, only the Brake light was on. The van seemed to have a great deal of trouble getting to any speed; eventually, it jumped/bucked, the light went off, and it seemed as if might actually be able to accelerate fine. However, I was not willing to drive it any more to find out.
The brake fluid level is just fine. I have had the pads replaced recently, and have not noticed any problems with stopping the vehicle. I am not sure if some electrical issue might be possible?
The vehicle has also stalled intermittently, has a hard time starting, and makes some noise (a whistling noise during low speeds, tapping while the van is warm at idle), but I have a feeling these are not related.
Any suggestions would be appreciated.
Old Nov 30, 2017 | 10:02 AM
cablesplicer's Avatar
Does shound like electic issue . Maybe loose connection . Try checking where you wires plug together , key switch and screws holding fuse box together. My screws were loose on the fuse box and gave me come and go troubles . I hope this helps .
Old Nov 30, 2017 | 12:22 PM
SBchevyfan's Avatar
If I am not mistaken, your wheel sensors are integral to the hub assembly. Check for wear in your bearings. Also get the codes checked for any stored codes in your ABS system. That might at least direct you to a specific hub.
