1996 G10 - Missing MAF Connector?
Old Aug 9, 2017 | 8:50 PM
Fortran's Avatar
Default 1996 G10 - Missing MAF Connector?
Greetings:
I have a 96 G10; it is a relatively recent purchase. I was looking at the van for what I suspected was a vacuum leak when I noticed that my MAF sensor appeared to be missing its connector. While it is quite clear that there needs to be a connector going to the MAF sensor, I am less positive about where the "other end" of the connector is supposed to go. I do notice what appears to be an absent connection on the air intake tube (very close to where the MAF connector goes)/ I suspect this is where the other end plugs into, but I am not certain. The van is a 5.0.
Missing connector.
Could anyone confirm or am I missing two distinct connectors? Also, where might be a good place to purchase just the connector?
Thanks.
Old Aug 10, 2017 | 12:09 AM
canucklehead's Avatar
Is it throwing any codes? is it the original engine?
Old Aug 10, 2017 | 7:03 AM
Fortran's Avatar
It is the the original engine to my knowledge. It is throwing a code related to the o2 sensor. Thanks.
Old Aug 10, 2017 | 7:51 AM
Twscarp's Avatar
Thanks.
Yes, you are missing two connectors, they should be part of the engine harness. That part of the harness should be laying on top of the motor, do you see any cut wires?
Old Aug 10, 2017 | 3:19 PM
kevinkpk's Avatar
Pull the maf itself, there are (as posted) two connectors. It could be lying underneath it.
