1997 Chevy van 2500
Old May 9, 2019 | 9:56 PM
JJMCOOLEY's Avatar
Default 1997 Chevy van 2500
Hi everyone, I'm new here, I have a 1997 chevy g2500 van A/C only works when I jump out the relay, Ive install new low and high pressure switch, also installed a new compressor, and accumulator, put 3lb of R-134A , any thought?
Old May 10, 2019 | 12:03 PM
Irish_alley's Avatar
I'm here for the party
does it run if you jump the low and high pressure switches? theres someone on here thats having that same issue
Old May 10, 2019 | 12:12 PM
JJMCOOLEY's Avatar
Hi I jump out the low pressure switch and it runs, also jump out the relay and it runs, Never tried the High yet Is that the one that plugs into the back of the compressor ? I also have a plugin on the top of the compressor , Thanks
Old May 10, 2019 | 12:30 PM
well i you might have found your issue, sounds like you dont have enough freon
