1997 Express 1500 soft brake pedal
Old Oct 8, 2011 | 4:00 PM
snaponbob's Avatar
Default 1997 Express 1500 soft brake pedal
AM stumped by a soft brake pedal and weak brakes. All new hardware at all four corners, new master cylinder and vacuum booster, all hoses good. Bled brakes properly including using a scan tool to activate the ABS pump. NO air in the system.
Any thoughts? BTW, not an amateur with tools, just baffled.
Old Oct 8, 2011 | 5:07 PM
EinST's Avatar
Welcome to the forum. Well, I am an amateur now but it sounds like you still have air trapped in there. Also, in those days they used weak accumulators in the BPMV that can bleed off the pedal generated pressure when an isolation/dump valve fails to close. Maybe you can try disconnecting and capping off one of the lines from the master cylinder to isolate the problem to the front vs. rear?
97RedBull
16
Jan 12, 2022 1:37 PM
next2nothing000
Oct 10, 2021 9:25 AM
hopakco
18
Jan 8, 2020 6:32 PM
oldtruckgoodtruck
Aug 21, 2016 9:04 PM
69rrvert
Oct 22, 2009 4:59 PM
