1998 1500 where to get spare wheel rear door carrier
Old Dec 17, 2021 | 8:42 AM
Ros's Avatar
Ros
Unhappy 1998 1500 where to get spare wheel rear door carrier
%subj% pretty much says it all. Apart from the spare wheel carrier I am trying to find running boards or complete body kit that would not diminish ground clearance (something like attached pic). My 1998 Chevy Express 1500 conversion van also needs right rear window (could be w/o vent). I am probably bad internet seeker, I found some shops, but they do not answer. Could someone please point me out to something?
Old Dec 19, 2021 | 4:39 AM
William Kisselstein's Avatar
I would start with salvage yards.
Now that you mention I can't think of an outside tire carrier for these vans. I don't think there is such a thing, because the spare was moved under the rear floorpan. The 1995 and older put it on the back because the factory stowage was in the right rear of the body.
The entire hinge design is different, so even trying to adapt an older one would be difficult.
Old Dec 19, 2021 | 10:28 AM
Ros's Avatar
Ros
Unfortunately, in my country there are no Chevys on salvage yards
Underneath the car, there is LPG tank on the place of spare tire. Outside carrier does exist, check these photos:
The same Chevy I got
I like this one as it seems fitted to hinges instead of drilling holes through doors
Does anybody have such a carrier? I am thinking of DYIng it and would like to get some info regarding size of tubes, thickness of bolting plate etc…
Old Dec 20, 2021 | 11:21 AM
pomerlo's Avatar
Here is mine
Old Dec 21, 2021 | 4:56 AM
Ros's Avatar
Ros
Originally Posted by pomerlo
Here is mine
Thanks, pomerlo. Would you be so kind as to send me detailed photo of the area around hinges (even if you open doors and there is visible how it is fixed, it would be helpful too) and let me know what is the diameter of the tube? Thanks again, ros
Old Dec 21, 2021 | 9:36 AM
pomerlo's Avatar
Unfortunately I dont have pictures of the door open. The van is sleeping in a barn right now for the winter ... But I can say the diameter of the tube is roughly 1 1/2 - 1 3/4 inches.
Dick Cale
Apr 26, 2021 6:39 AM
cygvan
15
Jan 28, 2016 6:20 PM
Chev98
Mar 27, 2014 9:47 AM
jeffrey d.
Jan 18, 2012 2:42 PM
davew2
Jun 16, 2011 12:16 AM
