1998 Chevy Express 2nd Battery Installation
Old July 5th, 2021, 4:57 PM
  #31
TrishaB's Avatar
Default What is your shopping list
Originally Posted by CoronaVan
The second battery is a deep cycle battery that exclusively runs the van's entertainment system. That system includes a 1000W inverter that runs a TV, BluRay, gaming system, etc. The inverter can also run other appliances that require "house power" (120VAC). Having a second battery on a battery isolator allows key-off use of the entertainment system without the risk of draining the van's starter battery. Hope this helps.
What is your shopping list for the second battery and do you know what type of mechanic can do the work?
Old July 5th, 2021, 7:14 PM
  #32
CoronaVan's Avatar
Originally Posted by trishab
what is your shopping list for the second battery and do you know what type of mechanic can do the work?
Below is my shopping list from a previous post in this thread. As for installation, it may be a job better suited to a car audio shop.
Originally Posted by coronavan
part price qty
a manual reset 150 amp circuit breaker $16.99 3
b soundbox 0 gauge red 1/0 wire 25 feet $28.95 1
c stinger sgp32 200 amp battery relay isolator and relay $43.76 1
d blue sea systems ato/atc fuse block (4-circ w/cover) $19.99 1
e installgear in-line agu fuse holder with 80 amp fuse $6.53 2
f pac pac-80 80-amp relay battery isolator $14.67 1
g upg 12v 100ah deep cycle vrla battery $179.99 1
h qc 3.0 usb charger socket panel $16.87 2
i qc 3.0 dual usb charger socket panel $22.99 1
i also used two sets of installgear 0/4/8/10 gauge battery terminals ($17.95), one feature that attracted me to these battery terminals is that they don't need terminal lugs crimped onto the wires​​​​​​. The 150a circuit breakers are the same way.
Old July 6th, 2021, 4:08 PM
  #33
GeneveConversionVan's Avatar
The only one I will double click is the isolator. Sometimes I would like to pick an "intelligent", sometimes the stinger is what I go for. Cant make my mind.
dberladyn
43
June 24th, 2020 5:06 PM
Richard Yao
Avalanche
January 10th, 2017 5:25 AM
Scotiapilot
March 15th, 2016 12:35 PM
Sirius018
July 17th, 2010 10:10 AM
chevydig
Cobalt
September 4th, 2008 5:23 PM
Quick Reply: 1998 Chevy Express 2nd Battery Installation
