2000 express 3500 abs nightmare
Old Jun 12, 2012 | 2:48 PM
green_rider's Avatar
Default 2000 express 3500 abs nightmare
Hi, I have a 2000 Express 3500 and recently the abs light came on. I hooked my scanner up to it and it through these codes at me; C0222, C0225, C0226, C0235, C0237, C0267, C0268, C0286. I realize that there is a common theme of shorts, or open circuts. I have checked the wiring to the plug but i'm stuck on one wire, the light green wire. It says in the wiring diagram that it is ind. ground. Should this be grounded all the time? there is no ground with the key on and even when i put a jumper wire on it, there is no difference. i have attempted to clear the codes a number of times with no luck.
Thank you in advance for any help.
daplumma
Aug 24, 2013 10:17 PM
keithpincock
Aug 1, 2010 9:16 AM
ShawnInDallas
Feb 27, 2010 8:18 AM
motorcityman
Oct 29, 2008 12:20 PM
closekutt
Aug 26, 2007 11:38 AM
