2000 express van 1500 4.3liter
Old Jul 27, 2013 | 8:57 PM
Highball's Avatar
Default 2000 express van 1500 4.3liter
Problem when driving the abs light comes on .the trans shifts funny and the speedometer is very erratic ..replaced the speed sensor and still does this. jacked the rear off the ground and ran the van .light doesn't come on so I back probed the frt. sensors left frt. voltage was 4.21 right frt 7.60 so I replaced the left frt. wheel sensor and the light still comes on .....What gives here...Thanks
Old Jul 27, 2013 | 11:21 PM
canucklehead's Avatar
Can you check the codes?
Old Jul 28, 2013 | 8:58 AM
Highball's Avatar
When I check the codes with a scanner there's nothing stored in memory ..
Old Jul 30, 2013 | 9:29 PM
Highball's Avatar
I found the circuit board on the instrument panel having (3) 100.J ohm resistors burned will let you know when repaired...
cas15
Dec 19, 2013 7:33 AM
ChaosComplex
May 17, 2011 11:07 AM
Cobrakidd
Dec 7, 2008 12:22 PM
ss_early
May 17, 2008 2:18 PM
dablazerboy
Feb 13, 2007 10:47 AM
