2000 Santa Fe rear heat option
Old Dec 13, 2018 | 7:21 AM
fredric58's Avatar
Default 2000 Santa Fe rear heat option
2000 Chevy Express 1500, Santa Fe with rear heat. (YF7 option) rear heater hose no longer available from dealer. Any idea where I might could find a replacement? Goes from forward passenger side lower intake manifold to aluminum pipe that feeds rear heater. Thanks
Last edited by fredric58; Dec 13, 2018 at 7:26 AM. Reason: didn't finish initial post!
Old Dec 13, 2018 | 7:36 AM
This might be what you are looking for.
https://www.hyundaipartsdeal.com/gen...odel=&Filter=()
Old Dec 13, 2018 | 7:50 AM
fredric58's Avatar
A heater hose is what I am looking for. The GM YF7 option added lines to a rear heater box. The hose that goes from the "intake manifold" to the line feeding the rear heater box is what I would like to replace. It's 18 years old.....
Old Dec 13, 2018 | 8:45 AM
StanVan's Avatar
15 Year Member
What is a "Sante Fe"? Is that a conversion? And what engine do you have? And have you tried Rock Auto?
Old Dec 13, 2018 | 10:38 AM
fredric58's Avatar
Default heater hoses
The Santa Fe is a conversion. The engine is a 5.7/350. with the GM YF7 options package/upgrade, (rear heat) GM no longer makes/stocks the hose. No, I haven't tried that. but will.
Old Dec 13, 2018 | 11:52 AM
Would a universal hose work or is there something special about this hose?
Old Dec 13, 2018 | 2:18 PM
Rockauto has a couple pages of hose for your van. Both pre-molded and "cut-to-fit"
Old Dec 14, 2018 | 8:07 AM
fredric58's Avatar
Yes I could go with a make shift but I would prefer original. Bound to be some NOS somewhere!
