2001 GMC Savana 3500 obd question
Old Jan 1, 2015 | 1:53 PM
jethat's Avatar
Default 2001 GMC Savana 3500 obd question
My 1 ton Savana has a unique OBD system. My generic OBD 2 scan tool and the ones at parts stores will not pull codes! My brother inlaws expensive snap on scan tool will. I've read 1 tons in some years were an obd 1 1/2 or something but there is very little information about it. Wondering if anyone has experiance with it. I'm tired of chasing down my brother inlaw every time I need codes (with this van I need them pulled a couple of times a year at least) I'd like to get one that works with it!
Old Jan 1, 2015 | 4:28 PM
what scan tool are you using? What modules are you trying to pull codes from. cheap code readers will only pull "P" or powertrain codes not "U" undefined, B body, C chassis codes.
if you want to retrieve these codes; get your wallet out.
Old Jan 2, 2015 | 2:34 PM
jethat's Avatar
I have a cheap Acutron or something like that. I wont pull anything from that van lights up attempts to scan and comes back with an incompatible message. Other cheap scanners have the same problem. Its the p codes I want. I get nothing..
Old Jan 2, 2015 | 7:23 PM
if the scan tool is powering up there must be power on the orange wire/pin 16 of the dlc which powers the scan tool. if there is no power at pin 16 check the pwr aux fuse 7 in the I/p fuse panel.
as far as I know this vehicle is obd2 compliant. I know Nissan vehicles from 96-2000 had both odb1 and ob2 connectors as part of a grace period as they were not fully obd2 ready.
Chevrolet Forum News
Jul 15, 2014 4:48 PM
Mutumbo
Dec 12, 2013 2:19 AM
Jan 21, 2013 7:18 AM
tcr1016
Jul 23, 2011 9:43 PM
russellhall63
Feb 13, 2011 1:53 PM
